Cleaning a Sony KL37-W2U
Discussion in 'Sony TVs Forum' started by Robbbo, Sep 11, 2005.
  1. Robbbo
    Robbbo
    I have been given a Sony KL32-W3U which has lived its life in a pub. The picture is drab and the colours lifeless. Having wiped off a century of nicotine from the cabinet I was thinking that the lamps are dirty.
    Anyone got a step by step guide to cleaning one of these sets?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,443
    Somewhere in South Yorkshire
    +5,852
    There's only one lamp, and you can remove it yourself (behind the speaker grille, front bottom right) to see it. Clean the "output" end of the lamp if it needs it. It's user replaceable, although new ones cost GBP300 or so.
    Probably, the whole of the optics inside the set have been coated with tar, too.
    You can safely remove the entire top of the set, down to the bottom 30cm or so. Remove screws at the back of the set to do it. Hard to describe exactly, but you should be able to work it out.
    This piece is quite light and contains only the screen, a mirror and a lot of empty space.
    Clean the back of the screen (inside) and carefully clean the mirror. Try your technique on a tiny area in one corner - you don't want to damage the reflectivity of the mirror.
    If you then look in the base of the set, right in the middle, you should see the projector lens. Whatever you do, don't move it (ie. change its focus). You can clean the top surface of this.
    There are probably other, more enclosed, areas (like the LCD chips and/or the prism block) that are coated, too. But to try and dismantle this area of an LCD projector is never a good idea, so - don't. You should get some improvement from the above.
    When you put it back together, check the air filter behind the grille at the front left. Clean and/or replace it if necessary.
    Mod comment As this isn't a DLP set, but an LCD rear projector, I'm moving the thread to the LCD forum.
  3. kourosh
    kourosh
    Feb 6, 2005
    14,676
    Portsmouth
    +1,048
    do be honest mate if thats been in a pub there's a real good chance the bulbs have had it :rolleyes: i would try and replace the bulbs :thumbsup: unless they have been changed recently :thumbsup:
  4. LV426
    LV426
    Jul 14, 2000
    13,443
    +5,852
    kourosh - you're clearly thinking about the wrong kind of TV.
  5. Robbbo
    Robbbo
    thanks for the info - 1hr spent this afternoon has brightened things up a treat, thanks again
