Cleaning a Plasma screen
Discussion in 'Plasma TVs Forum' started by lynneharvey, Jul 13, 2004.
  1. lynneharvey
    lynneharvey
    Feb 4, 2004
    30
    Scotland
    Simple enough request ... sorry if it's really obvious and I'm just a big dummy ... but I don't want to attack it with something I'll regret! I'm guessing computer screen wipes but .... help!
  2. jmack
    jmack
  3. Brogan
    Brogan
    Oct 9, 2003
    7,484
    Cary, North Carolina
    +482
    Mine came with one of those micro fibre cloths.
    I usually give it a very light dusting with one of those fluffy nylon dusters then use the cloth to remove and lingering dust.
  4. thfccambs
    thfccambs
    Jul 17, 2002
    21,171
    White Hart Lane
    +6,897
    What about greasy kids finger prints? :(
  5. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    Meat cleaver usually does the trick.
  6. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    he he
  7. lynneharvey
    lynneharvey
    Feb 4, 2004
    30
    Scotland
    Well thanks a lot for all your suggestions - I bought it from the site provided. Let's hope it works!!
  8. sharp_aquos_man
    sharp_aquos_man
    I use "Klear Screen". The only cleaning product recommended by Apple for their PowerBook screens. Basically a non-alcoholic, non-ammonia based liquid with micro-fibre cloth.
  9. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    i got the spray from ebay (toppdogg75) great stuff
  10. jmack
    jmack
    just ordered my self one, will let you know how it goes.
  11. thfccambs
    thfccambs
    Jul 17, 2002
    21,171
    White Hart Lane
    +6,897
    Been looking at this,but not to sure. :suicide:
  12. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    did u get the spray jmack
  13. jmack
    jmack
    yes and works quite well, just spray on and i use a glasses none scratch cloth to wipe off.
  14. lynneharvey
    lynneharvey
    Feb 4, 2004
    30
    Scotland
    Bought the cleaning stuff from Mr PC.co.uk - and have to admit that it put smears all over the screen. Quite disappointed. I then used a damp dishcloth and wiped dry with paper towel and that did the trick better than ever.
  15. cruncher75
    cruncher75
    Nov 1, 2003
    1,406
    southampton
    +115
    ive used it on my plasma and my tft works fine that was about a month ago and havent had to clean again since
