Classik Movie Di
Discussion in 'Home Cinema Buying & Building' started by Mike-M, Nov 30, 2004.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,263
    48
    Lincoln
    +30
    Can anyone tell me what the sound from the Linn is like. I have decided to go for a one box system (even though I realise I would probably get better from seperates).
    Are there any other makes I could consider around the same price point. What speakers would work with the Linn. I have some S1's at the moment. I like the sound from these so was thinking of moving them to the rear and adding S8 fronts and matching centre. Would this work or are there better options at the price.
    And one last question, does anyone know where I can get to listen to a good range of this type of kit in the East Midlands. I'm struggling to find anywhere within reasonable travelling distance from Lincoln.
    All opinions would be welcome :)
