Classical Music DVD-A ?
Discussion in 'Music & Music Streaming Services' started by Rock Da Bass, Jan 3, 2005.
  1. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,635
    EU
    +743
    Hi All,
    Can anyone recommend any good classical music DVD-A. I listen to Classic FM a lot in the car, but being the ignoramus I am don't really know much about classical music. Recently heard a version of Vivaldi's 4 Seasons on DVD-A and it sounded really good. Any other recommendations of composer/performerances on DVD-A? Preferably good music and good use of the DVD-A format.
    Many thanks for any replies.
    RDB :)
  2. Garrett
    Garrett
    Apr 21, 2001
    39,849
    2
    167
    The best thief you’ll never see.
    +6,516
    Gustav Holst - The Planets is on DVD-A .
    I do not know how good it is on DVD-A but it is a one of the best classical pieces of work which at least you should know Mars from it.
  3. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,635
    EU
    +743
    Thanks for that :smashin:
    Ordered from play.com. Comes with DTS 5.1 etc etc. At £8.99 I can't go wrong (didn't realise DVD-As were so resonably priced 'til now). Also bought 4 Seasons. Should be good as a couple of starters.
    RDB :)
  4. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    Yeah Holst is great I have that on DVD-A and SACD, check out some BACH and Vivaldi I forget the names of the specific discs, I will post back when I get home tonight.
  5. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    i bought the planets myself a while back and although i,m not knocking the music i found the mix to be no different than the normal stereo version,as to 5.1,well it seems to have been forgotten,anyone else found thisian
  6. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    I too was dissapointed with the 5.1 mix and soon sold it on ebay.
  7. Garrett
    Garrett
    Apr 21, 2001
    39,849
    2
    167
    +6,516
    Vivaldi's Four Seasons is one of the popular pieces, do not know if this is what you are on about.
  8. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,635
    EU
    +743
    Right, got 4 Seasons and the Planets. Both are excellent BTW but as above, the Planets DVD doesn't seem to do much with 5.1 channels, though sound quality and music are good.
    Any more suggestions for classical music DVD-As that anyone has bought?
    Thanks,
    RDB :)
    PS It's a bit of pain with DVD-A that you have to switch on your telly and go through the menu's to get DTS. I think I noticed this point in another thread and have got to agree it's a bit of a downside to DVD-A.
