Clarification of Plasma connectivity for Newbie
Discussion in 'Plasma TVs Forum' started by Justhe1, Sep 2, 2004.
  1. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Hi there,
    I have been reading the various threads regarding plasma choice and methods of connectivity with interest as I am in the middle of doing up the front room and have the go ahead from she who shall be obeyed to purchase myself, sorry us a plasma with a view to mounting it above the new fireplace.
    After using this forum as a great source of info and after much debate I have decided on the Panny TH-42PWD6 in silver. :)
    I just wanted clarification (in leymans turns please!) on a couple of points:
    1) I will have sky+, a Poineer 575D DVD player, and occaisionally a PS2 to connect to the Plasma. I have a Sony STB1070 digital amp that looks like it will switch sources and has svideo in/out.
    What board/s will i need to connect the above to gain best picture, and does the Panny come with a scart as standard?
    2) What is the most cost effective/quality tilting wall mount to purchase?
    3) Do those of you who have their screen mounted above a gas fireplace have any issues with either viewing angle (sore neck!) or heat issues from the fire?
    4) Where do I purchase a test DVD to calibrate the screen?
    5) And finally, where would the best place be to buy the screen c/w wall mount and appropriatte board/s for the best price/service??
    Sorry for all the questions, esp as I know they have kinda been asked before, its just that I'm struggling to make sense of it all and really want to order the correct items ASAP and fit next w/end if poss.
    Thanks in advance
    Justin
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  3. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Thanks pjclark1 for the above link, the deed is done - Couldn't wait any longer - have just ordered the panny (c/w scart connection) together with the poineer DV-575A DVD player.
    Should be with me on Saturday :clap:
    Now I just need to sort out the wall mount unit, leads and cable routing :confused:
    I take it I'll need another connection board to plug both the sky and the DVD in??
    Haven't been this excited since erm, I can't remember :thumbsup:
    J
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
