Civilisation III Question.
Discussion in 'PC Gaming & Rigs' started by Garrett, Nov 5, 2004.
  1. Garrett
    Garrett
    Apr 21, 2001
    41,145
    2
    167
    The best thief you’ll never see.
    +7,068
    I have just got the Deluxe Edition in it contains 2 plastic boxes (like for DVD’s). In the main Civilisation box is CivIII.
    In the other box it says there is a Fan Kit, Conquest, and Play the World but in the box the is only the first 2 and no Play the World. On load them and opening the files I can see no reference to Play the World.
    Should there be an other disc for this?
  2. t-force
    t-force
    May 2, 2001
    1,855
    Southampton, UK
    +145
    If I recall correctly, Conquests includes Play the World.
  3. Garrett
    Garrett
    Apr 21, 2001
    41,145
    2
    167
    +7,068
    On the second disc set it shows Conquest, and Play the World as 2 different game boxes. On Conquest it shows some solders and on the Play the World Half a globe showing Africa and Europe.
  4. t-force
    t-force
    May 2, 2001
    1,855
    Southampton, UK
    +145
    This is going to sound like a really stupid question, but have you tried installing Conquests and seeing if PTW gets installed at the same time? I was going to try and check the details at www.civ3.com, but the site appears to be down at the moment.
  5. Garrett
    Garrett
    Apr 21, 2001
    41,145
    2
    167
    +7,068
    :smashin: Thanks.
    Nothing comes up but looking at the box the first game has 16 civilisations to play, Conquest has 7 and Play the World 8 on loading Conquest I see I have the chose of playing 31. Ergo I think I must have Play the World. :smashin: Thanks.
    Shame they did not make it more clearly on the CD label.
    Know any good sites for coloured guides since the only instructions are on Acrobat Reader on a cd. :thumbsdow
