Cisco 806 QOS
Discussion in 'General Tech & Gadget Forums' started by HiZ, Aug 20, 2005.
  1. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    Just got connected to SIPGate vith and ATA188 ad its all looking good.
    I can't seem to get QOS configured on the router. I want to use LLQ but when i try to config the policy-map it seems the command is not available. I should really chase this on a Cisco frum but i thought i'd try here first.
    CHeers.
  2. tbanks
    tbanks
    Sep 25, 2004
    12
    is probably the wrong one, you may need IP Plus or something like that, if you have support with Cisco you can pull it from CCO
    TB
