cinetec model dvd2200
Discussion in 'Blu-ray & DVD Players & Recorders' started by stonewall, Dec 31, 2003.
  1. stonewall
    stonewall
    I have just recd the above model dvd at xmas!
    Can anyone sdvise me if there is a handset hack to change to multiregion?
  2. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    My Bro got one so I'd like to know this as well.
  3. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
  4. mackemansj1
    mackemansj1
    Hi mate i dunno if i should reply but my mother bought one of these for her bed room alough they play everything they wont allow u to change the connection so it stuck on com. I sen many people taking them back becasue of this.
    1) Switch to DVD mode (Press DVD on Remote)
    2) Press Setup
    3) Press >>>> (right 4 times) to go to preferences screen
    4. Enter on the remote control "1379"--this will display the current region code setting (default is region 2)
    5. Press the up and down arrows to choose your region setting. When set to region 0 your machine will play most titles
    6. Press setup again to save and exit the menu
    got from another site hope it helps mate it deffo works as i tried it before she took it back
  5. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,862
    2
    In a secret location with Jennifer Lawrence
    +9,726
    Moved to DVD players.
    Greg
    Happy New Year
