cinemateq launches HDTV switching tool
Discussion in 'News' started by John Archer, Jul 19, 2005.
  1. John Archer
    John Archer
    Following is the press release from cinemateq about its new HDTV switcher kit…
    "With the HDTV Switcher Kit, cinemateq comes up with a future-proof function extension for the Picture Optimizer Plus II (SDI). The HDTV Switcher Kit is designed for use in home cinemas, to run, say, an HDTV-Receiver and a Picture Optimizer Plus II (SDI) with only one cable connection to a high-resolution display.
    With this solution the display is automatically, after a single session of programming, always provided with the best possible signal via DVI or HDMI – regardless of whether it comes from an HDTV- or an optimized PAL-picture - by the picture optimizer plus II (SDI).
    The HDTV Switcher Kit supports resolutions up to HDTV 1080p or UXGA, is fully HDCP compliant and consists of:
    * cinemateq HDMI 2:1 Switcher
    * cinemateq remote cable ‘ppII’
    * HDMI / DVI cable (1m)
    * two adapters DVI / HDMI.
    The recommended street price for the cinemateq HDTV Switcher Kit in Germany is 569 Euros.
    To find out more, visit www.cinemateq.com."
