david43ni
Ok I have decided I am going go for Red Wall and Black celling and projector screen wall my dimensions I am working on our 9x 11
But I have two stupid corners that cant be removed.
Future project looking the end goal to be dedicated room might go fancy later on with a star celling and led lighting but not yet.
Room Layout and Video
Their is an av room off to the right bottom of room,that I would need to drill through bottom wall to get through. Ill do a better video as soon as I can get it.
Capet Choice
This is my carpet supplier
www.martinphillipscarpets.co.uk
Sample
I see the calls that if only movie viewing pm;y that you should go for full black I was thinking for this for paint.
But I saw a dream media theater video on youtube and the guy had his room done in this color and It looks nice the color around the speaker grill. Its not a massive cinema room but gets me a tight 100" screen.
I see also allot of calls for the option of getting my walls carpeted I may have to as simple fact this is a front room in a detached house so is near the road in terms of noise for my neighbours any suggestions welcome
IF I DONT go that colour I would go this
Paint Option
Farrow and Ball Black
Also our face plates worth it for the final finish into the av/room my walls appear to be pure concrete with only the smallest of gaps for the pasture board?.
So Far Equipment I am thinking off is Links I want 4k I dont see need going for 8k now?
Projection
Epson 6050ub Uk Model
Also for Screen
www.screeninnovations.com
Audio
Denon AVC-X3700H (Black) ( but I want to have flexibility of going in ceiling speakers so could go 7.1 later)
www.richersounds.com
Klipsch reference 5.1 but I want to have flexibility of going in ceiling speakers so could go 7.1 later
Klipsch R-820F 5.1 Reference Speaker Package | Premium Sound UK
Control Options
Finally what our my options to control it all am a developer programmer I would love something that could build my self in c# and xamrain forms.
But I know my options are harmony if not but i know I could go the elite. What is the earhomey developed in is their a custom remote out their based on windows embedded or anything?
www.logitech.com
Cant wait for this project am a single lad and dont see the room being used for anything else in future unless I move but i own this house thanks to my dad, 43 years old and only starting this project.
Looking forward to suggestions.
Capet Choice
Firework Twist Carpet - Firecracker
Buy now online the Firework Twist Carpet - Firecracker Red bleach cleanable hardwearing carpet suitable for all rooms. Lifestyle Floors carpets at the best price. UK, NI and ROI delivery.
Farrow & Ball Estate Pitch black No.256 Matt Emulsion paint, 2.5L | DIY at B&Q
Farrow & Ball Estate emulsion paint is a sophisticated choice for interior walls and ceilings – this tin covers up to 35m² per 2.5 litres on average.
www.diy.com
Paint Option
www.diy.com
Projection
Also for Screen
Zero Edge Pro | Screen Innovations
Finally, a screen that is truly custom. With nearly any option imaginable, Zero Edge Pro can be customized for a perfect fit in your space.
Audio
Shop for Denon AVC-X3700H (Black) Dolby Atmos AV Receiver with Richer Sounds for a 6 Year Guarantee, expert advice and Lowest Prices Guaranteed
Control Options
Logitech Harmony 950 Advanced Touchscreen Universal Remote
Shop 950 Remote. Features custom activities with automatic settings, motion-activated, backlit controls, color touchscreen, vibration feedback, and sleep timer
