Cinema Reality and PNR?
Discussion in 'Plasma TVs' started by peterakastorm, Sep 21, 2005.
  1. peterakastorm
    peterakastorm
    Do anyone use these features? And if you do, on what material?
    And a side question... Is the feature "Woobling" on the PWD8 the same feature as on the Hitachi? Never knew the PWD8 had a feature like that, before I read the manual... :rolleyes:
  2. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Turn them both off.
  3. peterakastorm
    peterakastorm
    Thanks Piers ;)
  4. peterakastorm
    peterakastorm
    Yes, and the side question ;)
  5. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Turn it off too!
  6. peterakastorm
    peterakastorm
    Why? I'm gonna do it, but why? ;)
  7. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Because the PWD8 should be bomb proof as far as image retention is concerned (OK it is still early days with the PWD8 but I can't believe it is worse than the PWD7 in this respect). The wobbler function simply isn't needed and if used with a scaler will, I think, cause problems.
  8. peterakastorm
    peterakastorm
    Ok, thanks... But I don't use a scaler... But this will still be an issue?
  9. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Just turn it off - you don't need it.
