blincoe73
Established Member
Hello,
Im hoping you can help me out here with a few things.
I have recently moved houses and finally after purchasing a four storey town house now have the room for a Home Theatre. I am a complete novice when it comes to systems etc, but am a true movie buff and usually only appreciate movies at the cinema (Im there about 4 times per week)
Anyway back to the new house. As its new the other half has put her foot down and says I cannot channel into the plaster or brickwork
Any ideas how I install/wall mount a 42 Plasma without having visible cables?
I thought maybe build a timber frame on the wall the width of my AV unit and about 3 inches deep from the wall, cover it in plaster boards and mount the plasma in the middle? What do you think.
Pics of the Room - Dimensions - 20' x 12'
I have also just purchased this stand for my receiver, xbox and DVD player
My final question. I have a budget of 1000 to buy a new plasma and surround sound.
I would like approx 42" screen - what would you reccommend?
Thanks in advance
Thanks in advance
