Cinea SV300 Bafta player
Discussion in 'Blu-ray & DVD Players & Recorders' started by kerraig, Apr 9, 2005.
  1. kerraig
    kerraig
    Hi there, i'm a UK residen with one of these academy DVD players. When registered you are given a code to enter that locks the player to your region. I was just wondering if anyone knew what the multiregion code is or how to obtain one?
    thanks
  2. zeropoint
    zeropoint
    Jan 7, 2004
    319
    +10
    Since this is a 'core component of S-VIEW, Cinea’s end-to-end system for protecting DVDs against unauthorized viewers,' I'd have thought that it would go to great lengths to prevent users from defeating region coding restrictions.
  3. kerraig
    kerraig
    yeah its starting to look that way.
    Which is a shame cos its a hell of a player.
  4. Gealt
    Gealt
    Mar 11, 2011
    I have a Cinea SV300 but after going thru 'loading' 'play' sequence when I press play it shows 'Not available'
    on a black screen. It plays cds but the sound is woeful. It says on screen after a factory reset that it is ready to play std. dvds. I have tried HDMI & scart connections.
    My local repair shop say it's not worth trying to fix it & probably no parts. The previous owner say it worked fine way back. Is it ready for the scrap heap?
