Cine 7 - Dead
KarlRobinson
Joined
Jan 8, 2002
Messages
159
Reaction score
Points
53
Location
Bedford
My Cine 7 seems to have no power whatsoever!!
No LEDS, no power on, no power nothing.
Any ideas? I know it has power going to it.
Any internal fuses to check etc?
Even without powerlights, can you hear any clicking or faint buzzing when you apply the mains. I've had a few Cine 7s fail in the switch mode power supply.
There are two glass fuses which are worth checking you will need to pull the power supply tray forwards to get to them.
There are two cross head screws on the front grill under the lenses undo these and slide the power supply tray out a few inches. Don't take it all they way out they are tricky to put back and you may disturb a few key components.
Thnx Roland,
But, not a noise to be heard, totally silent.
Had the board out and checked lots of fuses, all ok.
If it is this board, can it be repaired without having to take the whole projector down from the ceiling, I only noticed a few wires that could be unpluged going to it.
Or could it point to another part.
You can take the power supply out but you have about 8 little yellow multipin connectors (all should be colour marked or are differnt lengths) the EHT, Focus and earth leads and the EHT feed back line.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
