CHT-10 Sub Interconnect Recommendations
Discussion in 'Subwoofers' started by xtremecool, Dec 16, 2002.
  1. xtremecool
    xtremecool
    Dec 9, 2002
    25
    3
    Cheltenham
    I should have a CHT-10 sub in the next few days, but I am wondering if it comes with an Interconnect and if so is it up to the job?
    If not what would you recommend as a replacement?
    Jon
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Subs don't come with interconnects. Many people spend a fortune on interconnects but Hifibitz sell an Ixos cable for £9.95 for 3 metres which I have been using.
    Telephone them first to ensure that they have stock as I have been waiting for a few days for my 5 metre cable which isn't in stock.
  3. xtremecool
    xtremecool
    Dec 9, 2002
    25
    3
    Cheltenham
    Thanks for the info, only reason I asked is I remember that REL provided a low level interconnect & a high level neutrik connector and cable with most of their Q range and above.
    I will have a look on HifiBitz for the Ixos cable.
    Jon
