S slaine Standard Member Joined Jul 1, 2006 Messages 82 Reaction score 2 Points 33 Apr 4, 2015 #1 Good Evening I have connected my chromecast to HDMI port 6 on my Yamaha RXV-477 Av Receiver. I am getting audio no problems but i can't get a picture. Am i doing something wrong. Thanks in advance Slaine
mtenga Distinguished Member Joined Jan 27, 2013 Messages 12,876 Reaction score 6,607 Points 3,025 Location Beckenham Apr 6, 2015 #2 Are these things not designed to be plugged into the TV? Sound could then be sent by optical, for example, back to the receiver.
joost80 Established Member Joined Dec 13, 2005 Messages 290 Reaction score 91 Points 79 Location Amsterdam Apr 6, 2015 #3 mtenga said: Are these things not designed to be plugged into the TV? Sound could then be sent by optical, for example, back to the receiver. Click to expand... I have mine in the receiver as well. Turns on and off with it as it gets the power from the receivers back USB port. Works great. Don't know why TS doesn't get a picture. Is it something to do with the video setting of that hdmi port in de avr?
Graham N Prominent Member Joined Feb 24, 2004 Messages 1,710 Reaction score 323 Points 342 Location Cornwall Apr 6, 2015 #4 HDMI port might need assigning. Or to test it temporarily plug it into another HDMI port that you are using for something else
Saalty Established Member Joined Aug 27, 2014 Messages 392 Reaction score 206 Points 157 Age 39 Location Stoke-on-Trent Apr 6, 2015 #5 I'd be interested to see a possible solution to this as a workmate has the same issue with his RXA820 and I've been unable to find a solution so far.
