Chromecast audio
Discussion in 'Music Streamers' started by everett_psycho, Sep 29, 2015.
  1. paulrw
    paulrw
    Jan 3, 2009
    458
    28
    Essex
    +99
    Not sure it's been mentioned, but if you use an android device you can cast directly to your sonos play units, as well as GCAs. So no need to use sonos software at all.
  2. larkone
    larkone
    Apr 21, 2006
    3,972
    North Essex
    +909
  3. kingcr33ch
    kingcr33ch
    Dec 12, 2005
    1,918
    +83
    I hope Apple allows Apple Music to play with Chromecast audio, the device is awesome and the upcoming chromecast speakers look great
  4. Jota180
    Jota180
    May 24, 2010
    351
    East Coast of Scotland.
    +67
    No gapless on CCA and the devs say it wont be added. They suggest some crappy pseudo gapless nonsense.
  5. PTE993
    PTE993
    Nov 10, 2014
    47
    2
    12
    Hampshire
    +9
    I'm running Spotify through Chromecast which is attached to my AVR. However to log-in I need to enter a 4 digit passcode. Is there any way of bypassing this? It means I have to switch my projector on to display the Chromecast screen so I can read the code. It would be much more convenient if I could just connect without the palaver of needing to get access to the code? Any advice?
    It also seems to have over-ridden the native Spotify Connect connectivity...at least with my Android phone anyway. Not sure if that makes much difference in SQ?
  6. k-spin
    k-spin
    May 24, 2006
    522
    43
    London
    +122
    Are you using a Chromecast Audio or the video one?
    I've not been asked to enter a PIN when using Spotify on my Chromecast Audio (only had it a few days though).
  7. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +336
    Sound like you are running the Chromecast in guest mode. Run the Chromecast setup and switch off guest mode.
  8. PTE993
    PTE993
    Nov 10, 2014
    47
    2
    12
    Hampshire
    +9
    Thanks chaps...yep it is the video one... @limegreenzx thank you. Will give that a go.
  9. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    My CCA is just too unreliable. cuts out far too much
  10. larkone
    larkone
    Apr 21, 2006
    3,972
    North Essex
    +909
    It isn't your CCA, its your wireless. I have my 3 CCAs on an AC1900 router (5GHz) and they are completely stable. When I had them on BT Business Hub3 (802.11n) they were unreliable.
  11. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    oh really. I am on the latest BT Hub. What can I do to improve it please?
  12. Cebolla
    Cebolla
    Jan 27, 2013
    1,566
    +256
    The first thing anyone should do with the BT Home Hub 4 & 5 is to switch off the 5GHz wireless setting that syncs it to 2.4Ghz wireless (SSID sharing), that BT supply enabled by default.
    This improves connectivity/discovery issues with many devices (especially UPnP/DLNA supporting ones) and also means you can be sure that the CCA connects to the 5GHz wireless, by giving the 5GHz wireless its own SSID.
    Next go to the Home Hub's DHCP Table settings page and make sure every device that's listed is set to always connect using the same IP address. Revisit this page and do the same every time you connect a new (permanent) device on the network.
  13. daveb975
    daveb975
    Oct 25, 2002
    4,403
    103
    London
    +381
    Yep, I had the same problem (but with Sonos) and switching to CCAs on 5ghz totally sorted it out.
    I found that the 2.4ghz band in my area was very crowded and whatever I did, I couldn't get music to play properly. Strangely, streaming 1080p video to my Apple TV was no problem at all on 2.4ghz.
  14. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    thanks alot will try it now
  15. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    Hi Cebolla
    On the second part what IP address shall I use on all the devices please? 3rd column below is what I have
    DHCP Table
    Device
    MAC Address
    IP Address
    Lease Time
    android-459d043fc93991bb 00:EE:BD:AB:DD:D2 192.168.1.68 00:23:51:40
    Chromecast 6C:AD:F8:A4:9E:76 192.168.1.250 00:15:01:23
    Chromecast 54:60:09:FC:98:DC 192.168.1.164 00:22:23:43
    android-335eecebe9a01f5b 60:6D:C7:7C:66:8F 192.168.1.153 00:23:30:05
    BT-Mini-WiFi-Home-Hotspot-dcf 00:07:26:A7:BD:D0 192.168.1.76 00:23:49:17
    XboxOne B4:AE:2B:BB:C6:0C 192.168.1.81 00:23:58:15
    unknown_00:19:FB:86:E4:AB 00:19:FB:86:E4:AB 192.168.1.151 00:16:37:02
    RX-V673 9107C5 00:A0:DE:91:07:C5 192.168.1.165 00:23:49:34
    android-4ba3d1815d587380 88:70:8C:48:C9:25 192.168.1.65 00:21:08:28
    kindle-351d0974b A0:02:DC:BA:23:4C 192.168.1.120 00:21:04:41
    iPad 64:20:0C:A7:62:6F 192.168.1.77 00:18:41:57
    BT-Mini-WiFi-Home-Hotspot-dd3 00:07:26:A7:BD:D4 192.168.1.80 00:22:44:13
    Roberts-iPad 7C:6D:62:C4:86:97 192.168.1.245 00:13:39:41
    android-f5d045110dcf59a B8:5E:7B:AB:51:B7 192.168.1.193 00:18:24:21
    kindle-6f061d885 A0:02:DC:51:1B:54 192.168.1.248 00:20:14:40
    android-399573aefd70074c 40:F3:08:8A:FA:A0 192.168.1.149 00:21:52:38
    Rob-PC D0:27:88:80:25:CF 192.168.1.209 00:12:22:28
    android-bc3d8c2d63ca7b28 50:CC:F8:B2:7E:78 192.168.1.174 00:21:54:08
    Khalda 34:23:87:81:51:3F 192.168.1.234 00:18:59:43
    Robs-iPad 10:93:E9:45:26:79 192.168.1.226 00:18:58:12
    android-a845bebd3ae4950 D8:50:E6:2E:16:FE 192.168.1.155 00:22:15:59
    LTIBUK03987 60:57:18:D1:0D:85 192.168.1.224 00:23:15:43
    unknown_28:EF:01:FA:84:44 28:EF:01:FA:84:44 192.168.1.183 00:06:51:58
    iPad FC:25:3F:B8:32:74 192.168.1.243 00:18:32:53
  16. Cebolla
    Cebolla
    Jan 27, 2013
    1,566
    +256
    Holy carp, I didn't mean change the devices' IP addreses and certainly not to use the same IP address for every device!
    What I meant was to select every device on that list (that is permanent, ie, not a guest on your network), including WiFi ones, so iPads, tablets, phones, etc and make sure its "Always use this IP address" option is set to "Yes".
    There should be no need to change the default IP address assigned to the devices by the Home Hub's DHCP server.
  17. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    got ya, thanks!
  18. stigdu
    stigdu
    Mar 23, 2003
    2,056
    2
    Sutton
    +360
    I've been doing lots of research this morning and only just found out about the SONOS and this Google Chromecast Audio device over the past day or two. I'm a Spotify Premium user and use it on my PS4 in the living room and my mobile phone and headphones when out and about.
    I'm looking to be able to play music from my Spotify play list anywhere in the house.
    If I buy this Chromecast Audio device and a speaker, would I be correct in assuming I just plug it into the mains, let it find the home network, and then it will play my Spotify music there and then? If that is the case, can anyone recommend a speaker which will sound OK for <£100?
    Thank you!
  19. k-spin
    k-spin
    May 24, 2006
    522
    43
    London
    +122
    Just in case anyone is interested, this works with an iPhone too using AllCast. Although tbh I much prefer the Sonos software :)
  20. paulrw
    paulrw
    Jan 3, 2009
    458
    28
    Essex
    +99
    Thank you![/QUOTE]
    How about a bowers & Wilkins used zeppelin off ebay? you won't get better sound for £100, contains like 5 speakers and amps.
  21. stigdu
    stigdu
    Mar 23, 2003
    2,056
    2
    Sutton
    +360
    I'll go have a look, thank you Paul.
  22. kingcr33ch
    kingcr33ch
    Dec 12, 2005
    1,918
    +83
    I use Apple Music on iPhone and iPad, I'm in a family plan. Can I cast to cca from iPhone?
    Please say it's so
  23. everett_psycho
    everett_psycho
    Nov 20, 2009
    8,046
    Christchurch NZ
    +2,585
    I don't think you can, apple and Google no play nice. You'd need air play speakers for apps music
  24. larkone
    larkone
    Apr 21, 2006
    3,972
    North Essex
    +909
  25. kingcr33ch
    kingcr33ch
    Dec 12, 2005
    1,918
    +83
    I thought there may have been an hack from iPhone, think you can from android devices. May just buy a cheap android tablet, my current tablet is to old for Apple Music ...
  26. paulrw
    paulrw
    Jan 3, 2009
    458
    28
    Essex
    +99
    This poster says iphone works with Allcast app and CCA.
  27. kingcr33ch
    kingcr33ch
    Dec 12, 2005
    1,918
    +83
    Just wondering if they was using Apple Music though or another app
  28. k-spin
    k-spin
    May 24, 2006
    522
    43
    London
    +122
    I was using the music stored on my iPhone, not the Apple Music streaming service.
  29. paulrw
    paulrw
    Jan 3, 2009
    458
    28
    Essex
    +99
    Maybe if you are spending £130, you should get a sonos PLAY:1 for £169. Iam really happy with mine.
    I get more drop outs with CCA, and sonos is a great all in one speaker, press pause button on top and instant streamed music from where you last paused it, no need to power a control device up.
  30. paulrw
    paulrw
    Jan 3, 2009
    458
    28
    Essex
    +99
    You could upload your music to google play for free, and stream from there.
