Quantcast
Chrome Cable Tidy?
S
Sim1968
Had delivery of my Panny TH42PW6B last week, totally delighted with it. Have searched the forum to no avail about Chrome Cable tidy's. I have recently bought an Optimum 4 tier stand. Its lovely but its glass and shows all the cables at the back. I have chased the walls for the plasma (Scart and Component cables) But I'm under orders to tidy up the back of the stand. I was thinking about chrome cable tidy's?. Anybody know if these are available, where I can get them?
C
chachi
Originally posted by Sim1968
Only chrome/silver I am aware of is designed/tailored for PC use ... http://store.over-clock.com/Cable_Braiding___Sleeving.html
Might consider the maplin spiral natural/white depending on wall colour ... http://www.maplin.co.uk/products/module.asp?CartID=03090511535894&moduleno=26849&Products=5
rolandrat
Do you mean solid crome pipes for cables?
If so, I saw some in Focus DIY the other day - in the section for DIY shelving/cuboards etc - I think they are used for hanging stuff on etc (don't see the point of that, I just throw my stuff on the floor and it always gets cleaned and put away automatically!)
S
Sim1968
Thanks Elvis, looks like Vogels will do the trick. Cheers Chachi and Roland too.
S
sponshagga
Also pipe lagging looks fairly neat and its easy to fit
