ac-99
finally got round to putting some lights up this afternoon and by accident knocked my sky dish with the ladders... not very hard may a add
ran inside to find ni sky channels! looked in signal test and nothings locked!
i have a small black sky dish, quad LNB, dual cable run to 1 amstrad sky+ box
got back up the ladders to find nothing visually wrong apart from one nut which was a little loose... before tightening it i noticed the little level on the dish was out some, but when i tighened nut up the level was pretty much smack on....
checked the cable to the LNB and on the sky box.. all fine
powered off, disconnected all cables and powered back on to find no change... signal 'not locked' on both feeds....
haven't called sky yet and the sky+ box is less than 12 months old, its 11 months
is the dish and LNB covered?
any ideas what i've done?
any thoughts i how i can fix it or what to try?
haven't messed with any settings in the installer menu (401) before or after the knock
the only other thing i noticed whilst up there... on the side of the LNB it has numbers 12345 on the side... i think theres a little notch next to the 3, however in the signal test it says LNB 0002?
thanks for reading and any help offered
