Chord Odyssey Speaker Wire
Discussion in 'Home Cinema Speakers' started by Hawklord, May 17, 2003.
  1. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    I've just taken delivery of both my Linn Ninka's and Trikan speakers yesterday and I'm currenly bi-wiring with Van Den Hul Teatrack with IXOS 204 Bullion Series 4mm Dual entry banana plugs .
    Is my current speaker cable of the right quality to get the best out of these speakers? The guy's at Audio-T recommended I get some Chord Company Odyssey speaker wire which they quoted Seven metres of ody biwire is 7 x £34,18 terminated plugs x £3 is £54,total £292 with 10% discount hence £262 total- is this a good deal or would you recommend an alternative. I'm a bit reluctant to spend so much unless the benefits are major.
    thanks for any feedback.
    :smashin:
  2. eddiea
    eddiea
    Hi Hawklord
    I can speak from experience, I had VDH Teatrac Biwire on my AE1s when I changed my speakers for MA GR10s I used the VDH for a while then changed to Cord Odyssey Biwire, I dont think the difference was that much, they are both high end cables, I think the VDH was slightly warmer, but I have no complaints about the Odyssey.
    I would insist on trying a demo set at home before buying, if the dealer is any good they will be willing to provide a loan set, if not go somewhere else.
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    +294
    Thanks for that.
    I'll stick with the vdh if i'm not going to get a marked improvement and I tend to prefer a warmer sound anyhow.
    Would it be beneficial to get someone to terminate my current cable with better interconects and what sort of cost would I be looking at to do so?
    If I decided to do it myself what would I need and is it something a complete newbie could do? I'm ok builing my own pc's but when it comes to solderin' etc wouldn't know where to start.
  4. eddiea
    eddiea
    Hawklord
    I would not attempt to solder speaker terminals, I would have a specialist fit crimp on type such as Qed Airloc, see these links for ideas and prices :
    http://www.qed.co.uk/main.html
    http://www.hificables.co.uk/
  5. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    i use chord oddysey and think its excellent, if not a little birght. i got mine from a 7oaks and they did me 15-20% off without too much trouble, try a bit harder with the price, they can only say no:) i will be changing my cable soon as its a little too bright with my m&k speakers, the teatrack that someone else mentioned is a much warmer cable, the best thing to do would be to see if you can borrow some demo cables, if they have any - its a lot of money to spend on cable:lesson: :smashin:
