Quantcast
Chord Hugo Digital Coaxial - PIA!
kelly200269
The Hugo is an amazing unit, but owners probably curse the coaxial digital input. The casing is very tight, and makes it impossible to use most ordinary coaxial cables due to the size/shape of the plugs.
Chord Cable do a lovely Prodac Digital cable with one end fitted with a small coaxial plug - for £90 per metre! :-(
I've found a Belkin 2m coaxial digital cable with plugs that fit! Hurrah!
The cable is only £5.99 for a two metre length. I bought mine from Amazon. Happy days!
