Chord Chorus 2 Vs Chord Cadenza Reference
tazzo
Looking to buy either one of the two for near enough the same price.
The Chorus 2 will be the older model, while the Cadenza Reference is the latest design with the VEE3 plugs.
Looking for a fuller sound with louder (not better) bass. Clarity of sound and bass definition is secondary. Not to many reviews that I could find, help from users would be great.
Thanks.
tazzo
Moderator - Can you please move this thread to the "Home Cinema Accessories" forum please. Thanks.
Joe Fernand
AVForums Sponsor
'Looking for a fuller sound with louder (not better) bass. Clarity of sound and bass definition is secondary' - move your Loudspeakers closer to your wall, add a Sub, change your Amp, change your Speakers, add in room correction!
'a hallmark of the DH Labs cables. Exemplary background detailing, and a richer, fuller harmonic structure surround the extended bass response that one would expect from a 10-gauge cable' - surely no cable can outperform those characteristics :)
If you do believe that swapping over cables will make any difference then the only option is to try out the various cables in your system in your room.
Joe
tazzo
Yea, I think I'm just gonna buy a sub.
