Choosing the right system
Discussion in 'AV Receivers & Amplifiers' started by richiecas, Jan 10, 2005.
  1. richiecas
    richiecas
    Dec 29, 2004
    87
    I am trying to decide between the Sony HT-DDW760 or the panasonic XR-30.I have since come across the yamaha AV50. Can anyone recommend which is the best system. The room is 15*18 and I will be connecting sky+, DVD recorder, x-box and TV to it. No video connections will run thru it.
    Any experiences good or bad will be appreciated
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,079
    notts.
    +63
    The price of £170 from unbeatable is fantastic and the av50 will sound as good if not better than the other digital amps you have mentioned.The rxv 350 does have two optical and one coax so you shouldnt have any problems with connections.My son has the yamaha package that was previous to this one in his bedroom (18x12) and it does sound very good and for £170 is a no brainer.
    Cheers Gonzo. :)
