Hello,
up till now I have used video cameras we have at work that require to be connected to a pc to record anything, which is problematic at points. For that reason I am trying to find the right camcorder that can work on its own and then alllow for video file tranfer to pc for analysis.
The primary requirement I have for the camcorder is to record videos in colour in a room that is illuminated with fluorescent light bulbs to approx. 180lux and then give good quality image and to ideally cost less than £250 (the cheaper the better really as I will be buying it from work budget).
I do not need sound (and if there is sound ability to turn it off would be good) or HD image quality. But ideally I do need it to be able to work for about 8h constantly (so enough memory either internal or memory card and batter life to support that). I also usually film at a distance of probably up to 1.5m so the camcorder needs to be able to handle that.
The films will primarily be analysed on a pc but in a perfect world it would be good to be able to use them in presentation displayed with a projector (the image by no means needs to look good movie quality at this point but it would need to be more than just blurry dots for that purpose).
Obviously with our budget there needs to be space for compromise and so if the recording life is shorter than 8h, but longer than 30mins it could be worked around. Or, as I mentioned previously, if the image won't be able to be displayed in a presentation. The 2 things that I cannot really change are the distance of filming and the light intensity in the room.
I do appreciate it might be hard to find a camcorder to suit our needs, but as you can probably tell, I am a complete newbie to trying and source a video recording equipment and for that reason will be very grateful for any and all help.
Thanks in advance
saraneth
Thanks in advance
saraneth
