dariuscook
- Joined
- Aug 27, 2012
- Messages
- 1
- Reaction score
- 0
- Points
- 1
Hi guys,
New to this site - first post! But have been reading posts here for years. Ill give a brief introduction to my set up. I am a masters student so money is tight. Ive been looking to get a pair of monitors for years (my bro had a small home studio set up) and I loved the idea of active monitors, for their clarity and simplicity in amp set up, balance etc.. maybe it was my idea of having some sort of cheap audiophile set up where I can easily judge badly record albums and such. I understand the limitations in active monitors for listening purposes only, and sometimes i think it may of been better to of got a good 2nd hand loudspeaker/amp set up, but mainly when I'm listening to a badly mixed album.
In the end after going to a shop and testing the KRK 8's and the yamahas hs80 i went for the hs80. I felt they were clearer on all different types of music that i listen to (which is extremely varied, but to give an idea i like beirut and yeasayer first albums (a lot of vocals and instruments), along with deep electronic such as Alix Perez and Holy Other, and of course classics such as Pink Floyd, Radiohead. Im also a big hip hop fan) So i got the hs80, some balanced xlr cables and a cheap wharf dale usb mixer (was about £35) to use as my DAC from my macbookpro. after playing around with speaker placement and using the EQs switches on the back of the yamahas i found putting the highs and mid to the -2db position to be most favourable in listening after 2 weeks playing around. I use a program called Fidelia on my mac, to listen to my FLAC collection, otherwise iTunes on mp3 320, and have a very small 'smiley' EQ put on (at about a max of 0.75db at the smiliest ends). This seems to work quite well. But i do feel like I miss music in the very low end on my electronic music and miss a deep kick on drums and some hip hop beats (with or without any form of EQ on the speakers and iTunes)
In one room i wasn't too impressed by the bass from it. But after moving rooms after 6months, my speakers were now against a wall and produced a strong bass effect. Even after moving them away from the wall and cutting the bass down to -2db i still found that they were quite boomy and slightly undefined. I use the speakers for listening to music, predominately with a lot of bass, and also for movies. It was always my idea to get a sub and DAC along with it when I have the money.
So now I am interested in getting these two subwoofer:
- Matching Yamaha HS10w subwoofer (30hz range, 8" cone, £430)
- M-Audio Sb10x Subwoofer (20hz range, 10" cone, £250)
I was always thinking of getting the yamaha sub to have the ideal/natural 'balance' between using matching sub and monitors. But they are fairly expensive for my budget (no way want to spend over 450£), and the response goes down to 30hz and with having an 8" cone the same with my monitors I am fairly off put by this. The M-audio is a cheaper option, provides a cutoff switch (to provent neighbour annoyance easily at night!), and goes down to 20hz and having a larger 10" cone.
I guess my question is, does the yamaha have more benefits with it being paired with the my yamaha monitors over using the m-audio? Of course i like to get a lot for my money, and having the sub going down to 20hz seems much better than going down to 30hz (which i believe my monitors go down to 40hz already). Will this 10hz make much of a difference? How will the pairing differ? I would plan on putting the crossover at 80hz. Also on a side note, by using a sub and crossover with it, will I be able to get a louder sound overall for the occasional party, by not loading the monitors so much?
My next question is Im looking to upgrade on my DAC from my cheap temporary wharf dale, with a DAC having a USB input for use with my laptop. Im looking again to spend about 200-300£. Will i really notice the difference in a better DAC? At the moment i find my cheap one sounding a bit digital and jittery. Ive been looking around and i was thinking of getting one of these:
- Cambridge Audio DACMagic (USB in, XLR out, £230)
- Cambridge Audio DACMagic Plus (USB in, XLR out, volume knob, £350)
- Arcam rDAC (USB In, RCA out, £280)
Ive heard very good reviews about the arcam but I am looking on connecting my monitors (via my sub) straight in my DAC, and the arcam only has RCA outputs. Is this much inferior to using XLR cables? I prefer to use XLR cables as the connection is sturdier and because their is interference on RCA cables you can use cheaper cables to little effect on XLR.
I really like the look of the CA DACMagic, its a nice looking box has a variety of inputs and outputs of course with the XLR out. I then stumbled on the updated DACMagic Plus, which is supposed to have slightly better 'insides' giving a better sound output. I am not bothered by the possibility of the bluetooth connection (its nice and could be used with my iPhone, but I'm not bothered to spend another £70 on the bluetooth dongle). But I am very interested in the volume knob it has. This can be used in 3 ways, as a volume knob for headphones (which i won't be using it for), as a volume knob for XLR output (acting as a type of pre-amp), or turned off to use a true line level on the XLR output. I am wondering what the effect of using the volume knob will have on the sound quality instead of using it as a line level and adjusting the volume on my laptop? Is there much diffence? (My monitors are always in neutral position at 12 o'clock.) I like the idea of the knob as it gives my setup more of a hifi feel to it (as in a physical aspect to it), makes it easy to adjust the volume. And if I'm connecting my PS3 via optical out (to get Blu-Ray audio through it) I can adjust the volume easily using this. Im also using a standard USB cable (i think around £5), would switching to a high quality USB cable (say around 50-100£) make an audible difference?
I would also like to add an ipod/mp3/headphone jack (for a friend coming over etc..) connection in my setup somehow. The only way i can think of is by using a jack to RCA connector straight to my monitors (via Sub) , but this would be bit of a hassle as I would have to switch cables around. Is there a DAC which could have USB in, Anaolgue in, together with a XLR output and potential volume knob also? Or is there another way around this using my potential set up above, (is there a RCA to Coaxial cheap adapter even possible? bare in mind that I'm not too bothered about the iPod connection having the best quality, just for ease)
Please forgive me if i have got some technical things wrong here, I am new to audiophile and learning every time, so please correct me anywhere, Im sorry its so long, just trying to explain everything I can. If you can please give me some advice and some tips, it would be so so appreciated!
Many Thanks,
Darius
Many Thanks,
Darius
