choosing a Multi-region Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by SR1, Feb 19, 2002.
  1. SR1
    SR1
    Hi everyone,
    I need some advice here as i am trying to aquire a decent, reliable, true SELECTABLE MULTI-REGION DVD player here in the UK.
    I have seen a few like the YELO 800 and the MANHATTEN 3000 but i was wondering if any well known makes such as Pioneer or Sony do out-of-the-box multi-region too?
    If not, any recommendations would be good cos i need to be able to select region (for RCE) and play region 1 (and maybe at some point others).
    A budget player would be good, like theones i named above, but i can stretch to other prices, so tell me of any good ones you guys know.
    Any help would be greatly appretiated, thanks guys
    SR1
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Most of the name brands need to modified as they are not multiregion out of the box.
    If you´re looking at budget players, the best out there is the Toshiba SD210, its auto region select and will play RCE titles using the R1 disc swap trick, takes all of 30 seconds so no hardship, its also got cracking sound & picture quality.
    Available at
    www.richersounds.com
    www.leconcepts.com
    cheers
