Choosing a 7.1 Amp
Discussion in 'AV Receivers & Amplifiers' started by Soundager, Dec 20, 2003.
  1. Soundager
    Soundager
    Im looking to put together my first seperates system ,i want to purchase a 7.1 amp so i can build on it later.
    Ive looked at yamaha's,pioneers,and dennons..but there 7.1 amps are way above my budget im looking at spending a maximum of £400,are there any you can recomend for me?
    Thx for ure time
    Tim
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    tight budget for a 7.1 amp mate!!!! 6.1 no worries but 7.1??? i know of no 7.1 amps under £550.
  3. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    You could find a 2nd hand Denon 3801 (no Pro-Logic 2 though) or 3802 for around 400 quid. Both are 7 channel amps. :)
  4. bobbypunk
    bobbypunk
    AVR2803 is 7.1 (Seven amplifiers) @ £650 but the AVR1804 (Both denons) are 7.1 (Shared rear surround amplifier) and retails @ £400
