Choose me a LCD in the price bracket of £500 to £700
Rookies
Ok I have been looking round this fourm today and am finding it very hard to choose what LCD to go for
So please choose me one between £500 to £700 the lower the better please it for bedroom HD ready is not really needed but good for future proof I suppose
There you go guys a challange
Rookies
That looks lovely Better go and see one working, Is it very good picture wise and the like and it deffo HD future proof ready for when I get Sky HD?
Also trying to find out if it capable of going on the wall??
neilmcl
He said it was "HD Capable" not HD Ready, ie. it will still receive HD when available but display it at a lower resolution. Not a great deal of difference on a 26" though.
Moogle
The other option would be the Samsung 26" model that can be had for around 550 to 700 online. There are four variations of it, LE26R41B/LE26R41BD/LE26R51B/LE26R51BD. This one is HD ready and future proof.
Rookies
I looked at a samsung today not long ago at John Lewis and quite like it. Which of those modle the best or are they all the same?
domtheone
I think the differences between the 41 and 51 are cosmetic only and I think the ones with the D on the end have intregrated Freeview.
Moogle
The ones with the D in the model number have an integrated digital tuner ( IDT ). The ones with 51 in the model number are exclusive to the Dixons store group ( Dixons, Currys and PC World ) and are slightly cosmetically different with the triangle bit on the bottom being partially black as opposed to all silver on the 41 models.
Shook
I got my Samsung LE26R41BDX from waratah for £611 and it's superb. I couldn't be happier. And properly HD ready for the price, it really is a bargain.
I have to say tho, that Sharp is a beaut, if you're not bothered about HD.
The Aquos TV's have a great picture.
Rookies
Ok Guys am more toward the Samsung now. Is it good With standard RF signal if I have a good reception? As I am moving house soon and this tv is to go into my bedroom and I am thinking of holding fire on getting my current sky plus refitted into the new house and hold for the Sky HD. Or should I get my current setup installed by a local fitter and then upgrade later what you all think
cozzykim
Hi all,
sorry to jump in with this one
How big is your bedroom Rookies?
How about this one:-
http://www.amazon.co.uk/exec/obidos...3767339-3591837
I've been looking for a decent spec 32" LCD for a while, almost bought the woolies 32" Crown until found out on here that it has no VGA input in current form.
So, I found the Video7 in that thread an' went 'n' ordered one.
Will post impressions when it arrives.
Also it ain't that difficult to install your old $ky by yourself, if you can drill four holes in your house wall and the dish can 'see' 19E then it can be done even without a sat finder - mine was - search the forums for instructions or to be pointed in the right direction.
Give it a go
Good Luck
neilmcl
Sky will reinstall you're Sky+ for free if you move home. I still say if you only want a bedroom LCD for watching SD material then you're better off with the Sharp.
Rookies
Well I plan to go SKy HD in Feb so will this sharp me ok for it? There a few different sharp please link me to the one you suggest please
neilmcl
If you wnat to watch HD in all it's glory then the P50 probably isn't the one for you. Try the GA6 instead or look at the Panasonics.
Rookies
Thankyou for your help, Are you suggesting I should not go for the samsung? The reason pls?
andrewfee
I have the 32" Samsung LE32R41BX and would personally not recommend it. I have had two faults with mine, am in the process of getting a refund, and will be picking up a Sharp LC32GD7E to replace it. (£1400 though; a little out of your budget, and the 26" is £1000)
It does not handle SDTV well at all in my opinion. It does not do a good job of de-interlacing, which results in a smeared image. It is good with 480p, great with 720p, and poor with 1080i. The Sharp P50 should look fantastic with all inputs. True; it won't look as good as a 720p panel with 720p content, but it should look better than a 720p panel with any other resolution. The difference at 720p is very minor though.
A 720p LCD will have to "upscale" normal television (note: SkyHD will only have 6 HD channels, the rest will still be SDTV) which essentially means it has to "guess" and create information out of nothing. (interpolation)
The Sharp P50 will run SD content natively (no scaling whatsoever) and will downscale HD to fit. This means that you lose some resolution, but downscaling, if anything, makes images appear sharper. HD will still look fantastic.
At 26" I'm not sure how much difference you would really see between native 720p and downscaled 720p to be honest, but you will definitely see the difference between native SDTV and upscaled.
The only reason I am going to be buying a 720p panel is because I'm a gamer, and from December onwards, 99% of the games I buy will be running in 720p, and the resolution is very important there. (not so much with television/film) If you just watch television/dvds, unless you're planning on being an early adopter of BluRay & HDDVD (probably about £1k each for a player, and there are talks of £30/movie) you won't be seeing much HD content for some time.
If I wasn't a gamer and watching regular television was a concern, I'd be buying a P50.
Rookies
Many Many thanks for your ace reply Hmm Alot of people have said the Sharp me best for my need as I only for Sky And TV really. Maybe best going down that route then, Even though it is ok for HD it can take HD signals but not at full performance but you all saying I wont see that much of a different as only watching sky and tv
D
dkboy22
I tried to take some photos for comparison between a 37" P50 and a 37" HD Ready Sharp LCD, both running 720p HD demo material - see this thread:
http://www.avforums.com/forums/showthread.php?t=252410&page=1&highlight=P50
I'd struggle to tell the difference at normal viewing distance, even on a 37". Therefore, difference should be negligible on a 26".
neilmcl
If you don't mind me saying you seem a bit confused as to what you want out of a new LCD. Is it going to be normal Sky plus DVD use, or SKY HD and any other HD content you can get you're hands on, ie. HD DVD/BluRay, Xbox360 etc, or is it as I would guess a combination of both. If you want a compromise that's going to give you excellant results with standard Sky TV and DVD as well as being able to display Sky HD if/when you get it then the Sharp P50 is the one to go for. On the other hand if you're going to leave standard TV behind and solely use it for HD next year then a HD Ready screen is for you, possiby the Sharp GA6 or GD7.
Stinky985
i am thinking of a sharp too but have a couple of quick questions - is the 32" 16:9? the sharp site says Screen Resolution 960 x 540 x RGB ??! And will it display NTSC material properly/well? Ebuyer selling the 32" P50 for £810 ish. not searched anymore yet but still a good price. or is the Toshiba WL56 better for samr price?
Stinky985
ok cheers - is this better than the Toshiba? i watch freeview and DVDs and the odd xbox game and would (maybe) use my pc though it.
Latest News
Google set to launch the Pixel 7 and Pixel 7 Pro smartphones
  • By Ian Collen
  • Published
Focal launches Bathys noise-cancelling wireless headphones
  • By Ian Collen
  • Published
Formovie Theater UST projector hits the UK
  • By Ian Collen
  • Published
Sonus faber unveils new flagship Arena speaker series
  • By Ian Collen
  • Published
Sharp showcases its upcoming 4K TV and audio line-up
  • By Ian Collen
  • Published
