Choices,choices
Discussion in 'Plasma TVs' started by GCDB, Jan 7, 2005.
  1. GCDB
    GCDB
    Sep 23, 2004
    320
    Wrexham
    Hi all.
    I have been reading these forums for a while and asking a few questions about what to
    buy.I want either a 42" plasma or a 37" lcd and cant make my mind up due to several
    factors.
    One being is i cant seem to find locally a good set up for either. I was thinking of the
    pw6 but only have seen one displaying a component dvd signal, not a sky/freeview
    signal,but even better would be to see a signal from a stb js rgb to vga which is
    recommended.Does anyone know of anywhere local to me(wrexham) which might be able to do
    this setup.The same goes for a 37"lcd(thinking of sharp as local factory and can get
    reduced prices from factory outlet).The philips is a little over budget for me at moment.
    The advice to go for either plasma/lcd seems to be go and find a good setup for each(ie
    not currys etc) and see which you like best.
    Would the vierra showing freeview in currys be an example of what sky/freeview would be
    like on a pw6 as it is the same panel? dont shoot me for that if im wrong!
    Anyway my budget is really only up to 2k and also not sure what the pw6 would be like for
    ps2 or xbox(future buy dont tell wifey) with the sd panel.
    The viewing would be mostly sky/freeview with a few movies per week.
    Any help appreciated.
