Choice of television
Discussion in 'TVs' started by mobily, Jan 4, 2004.
  1. mobily
    mobily
    Dec 30, 2003
    477
    Plymouth
    Hello all,
    After a lot of thought and I have finally chosen the sony dav-s550. With budget and space in mind I believe I have made the right decision for my first home cinema system. It also plays cd's to a high standard too!
    My next dilemma is what television I should purchase to accompany my system. I have my eye on a couple of televisions. Mainly the JVCAV28T25 which my dad has and seems to be an excellent tv.
    However the other television I have in mind is the following:
    http://www.dvdltd.co.uk/product_info.php/products_id/378
    I am just wondering if anyone thinks this television would suit my system. The reason I am leaning towards this one is the component video input. However I am yet to visit Comet to see how the 100hz copes with football/fast moving films.
    Any experiences people have had would be gratefully received,
    James :p
  2. Kahless725
    Kahless725
    If you do a search for 28zd26 then it will bring up all the info people have on here about it, (there is quiet a bit).
    Personally if you have seen a tv as intimately as you will have been able to with your dads set and liked it then if you get anything else and it has a quirke that is beyond what your dads set is like your going to be dissapointed.
