Choice of HDMI Wall Plate
NuklearNik
Looking at the variety of wall plates available would somebody please explain the difference between those which are quite simply a coupler mounted in a plate and those which use some circuitry, or at least a pcb, between the two sockets? What are the advantages/disadvantages of each approach? The price range is significant too, anywhere from £6 to £50. Welcome the thoughts of the assembled crowds. Thanks
Joe Fernand
AVForums Sponsor
Hello NuklearNik
Whilst they look quite neat where possible its best to avoid a 'connected' Faceplate and instead go for the Brush style plates that let you push pre terminated cables through a hole in the face plate.
If you insist on using a connected Faceplate you need to factor in the total cable length (to the Faceplate + from the Faceplate) when deciding on a Passive or Active (with inbuilt extender) Faceplate.
Test everything before you bolt it in place - a nice 'looking' install doesn't always play ball when you try and use it when it comes to HDMI!!!
Joe
thecount
could you point me in the direction of such a faceplate you would recommend? my electrician has run a hdmi cable and its just sticking out of the wall at the moment! need o tidy it up somehow!
Joe Fernand
AVForums Sponsor
We usually have single and double gang 'brush' plates in stock - give the office a shout (after 10.00).
Joe
thecount
having a problem where we can't get the Hdmi cable through the metal cage which usually gets screwed to the breeze blocks - any ideas? I think the large Hdmi plug ends are a bit on the wide side and the electrician won't cut them larger as he says it also needs a grommet?
Joe Fernand
AVForums Sponsor
Shoot the Spark :)
If he/she cant cut the metal box use a plastic back box instead - if you cant get a large enough grommet use tape to protect the cable from sharp edges on the box! !!!
Joe
