choice of av receiver
R
ric_hall
I'm intending to make a purchase(first purchase - novice) of an av receiver, speakers and all relevant cabling .
Its currently a choice between the:
Technics SADX750
Yamaha RXV396RDS
Aiwa AVD58
It will primarily be used for listening to music, but will(on occasion) be used for DVDs . I would prefer that anybody that makes a recommendation also include a basic reason as to why they came to choose that particular receiver over the others .
Thankyou
R
ric_hall
Rather than choose from the three receivers, I'd rather get an answer about a particular model .
I've seen reviews for the Yamaha 393 and 596 model receivers, but not the 396 model . They both rate the models as being fairly good value for their price range(s) .
Assuming that the build quality for the 396 model is up to the same level as these reviews would suggest, would I be correct in saying that the 396 model is a good choice of receiver?
joshua_bond
Ric,
May I make a suggestion....if you can raise £50 on top your budget for the amp/receiver (only) then check this out: Look at QED-uk.com, empiredirect.co.uk and look at brands like Yamaha, Kenwood and Sony. Go for one with at least prologic 2. This is one the basis of price/feature (nothing to do with your tastes). For your money my choice would be Yam430 (with PLG2 and virtual 6.1). For cables, interconnects etc check out your local richer sounds.
R
ric_hall
Thanks for the suggestion, but I will probably just stick with the 396 due to the fact that the current layout of my room generally prohibits the use of anything above a 3.1 system . By the time that I have picked up a centre speaker and subwoofer, and I am looking to add some surrounds to my (intended)set-up(in addition to changing the room layout), I will probably end up buying a new receiver anyway .
I tend to take the view that when you buy any first generation piece of kit(first generation Pro-logic 2, ES/EX receivers in this case) you'll be paying more for the equipment and will have to deal with any teething problems .
B
Brad_Porter
Please bear in mind that if you listen to a maojrity of music (rather then DVD) then you compromise sound quality by buying an AV unit. AV units just done give a good sound.
You might already know this but I thought I had better just add my 2p's worth so you dont get an AV unit and wonder why it sounds a bit poor.
R
ric_hall
I realise that the integrated nature of the AV receiver will mean that it performs more poorly than a separate amplifier, tuner and decoder, but considering the monetary constraints of my budget I simply do not have much choice other than to go down that route .
Shockabuku
ric, I'd have to agree with brad here. If you're only looking at using the receiver for 3.1, then the main attraction of an a/v receiver/amp (multi-channel surround) would be wasted. Why not go for a stereo amp (which at that price point would sound a lot better than an a/v receiver) and just run films in stereo? Unless you really need the tuner, of course, in which case perhaps a stereo receiver is worth looking at...?
R
ric_hall
I had initially considered looking for a stereo receiver, but even if I went for another receiver when I wanted to expand to 5/6/7.1 surround, I would still end up requiring the 5.1 channels as the (old) receiver would be set up in another room(although not necessarily with the same speakers) .
B
Brad_Porter
The unfortunate thing here is that your budget is your enemy. I dont really know any good units for this price - they are out there though.
Can someone offer some good advice for Rics £150 budget for an AV amp?
S
sconepanman
How about looking for a second hand Marantz? like the x000 series. V. good with music and you should find a 5.1 receiver for about 150 in decent condition.
J
Jason S
I've got a Yamaha RXV396RDS that you can have for £50 + postage.
I've recently replaced it with a 630 model so it's in the spare room at the moment. I was going to stick it on ebay / in the sales forum, but never got around to it.
R
ric_hall
I'm willing to purchase said item, but I will only purchase under certain conditions
My contact e-mail is [email protected]
This is a web account(not my main account, which I am not willing to post on this site) which generally does not accept attachments .
My location is Lanarkshire, Scotland
In any e-mail you would need to specify:
where you live(it might be easier to collect)
what your e-mail address is
what your name is
what is included in the box(unit, power cable, aerial, remote, etc.)
what condition the item(s) is/are in(what state, guarantee details(expired, etc.), plus how long you've had it)
what method of payment you'd expect for the item
how much you want for the item
the expected cost of shipping
Note: If I collect then I will need to see the unit in working order before purchase . If I do go ahead with the purchase and it needs to be shipped then I will likely only accept it either on approval, or with an initial deposit(likely to be shipping only) . Upon arrival of the item if I find that it is in someway damaged, faulty or items are missing then I would return the item to you and refund your shipping costs . Otherwise, I will pay the remainder due to you in full . I will obviously include a valid name, address, e-mail(main account) and telephone number, and will look to have a telephone conversation with you before agreeing to any exchange of goods/money .
If you do not agree with any of the above conditions or wish to re-negotiate the price, etc. then I suggest you say so in any e-mail you may send to me .
I will not reveal any of your contact details with any persons not directly related to the purchase if you do decide to contact me, and would expect that you do not reveal any of my contact details either .
Thankyou,
Richard Hall
R
ric_hall
I don't personally know the person so it's a case of 'caveat emptor' or 'buyer beware' .
bob1
:eek:
