Choice of 3 Systems
Discussion in 'Home Cinema Buying & Building' started by mranarchy, Mar 11, 2005.
  1. mranarchy
    mranarchy
    I am looking to buy an All in one home cinema system for my living room.
    I have narrowed the choice down to 3 systems
    1.Panasonic SCH520
    Great reviews,but doesnt seem to upmix stereo from TV source and volume is a bit low
    2.Pioneer DCS 222
    Looks good ,sounds good ,multiregion
    3.Sony DAV SB-200
    Good system,lots of power,not multiregional,but has floor standing speakers which I like.
    I already have a DVD player and the most important factor in buying the system is the sound aspect not the picture.
    I want a good clear powerful system so I can watch lots of DVD's and upmix standard Tv.
    Anyone have experience of any of these systems or are they all good and I cant go wrong ?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    the panny is ok....but as you have a DVD player why buy an all in one? why not buy a basic AMP and spekaers? how much do you have to spend with the CANTON CD1 speaker (much better than any sub £1000 all in one for £240 delivered and a basic AV amp for £100 you will get a much better sound..........
  3. mranarchy
    mranarchy
    Dont want to spend more than 300 euro in total.
    Would the 3 systems I mentioned be any good ?
    The Cantons look good but I cant really afford them at the moment after buying my projector.
  4. mranarchy
    mranarchy
    I am thinking of pairing a Pioneer VSXD 514 receiver with a set of Yamaha NSP 100 speakers .
    How would this perform ?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    great amp poor speakers look at canton movie 6 CX and CD1......
  6. mranarchy
    mranarchy
    Okay how about the Pioneer VSXD 514 receiver with the Canton Movie 6 CX speakers.
    How would that compare with the 3 all in one systems ?
    Also do any cables come with the Canton set ?
  7. Jake James
    Jake James
    Dear mranarchy
    The canton system will spank the other systems into oblivion. Big time. and its more discreet.
    If you want any info on the movie 6CX let me know.
    regards
    JJ
    Hi to HD
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    CD1 and above dont come with cables, but the movie 6 CX may come with cables......
    Spank, eh JJ? they will be better than the other systems proposed.........
  9. Jake James
    Jake James
    Canton Movie systems do not come with any cables
    Movie 6 CX
    Movie 10MX II
    Movie 6.1MX
    CD1
    & satellites
    CD10
    Plus MX
    all the above come with brackets to hang on the wall
    regards
    JJ
  10. mranarchy
    mranarchy
    How would the Yamaha AV 50 Package compare with the Pioneer DCS222 system ?
    I've decided I'll go with one of the above.
    Any recommendations ?
