Choice of 3 32"LCDs.. Bit of advice required
Discussion in 'LCD & LED LCD TVs' started by groovyf, Sep 7, 2005.
  1. groovyf
    groovyf
    Jan 10, 2005
    78
    I've been looking at:
    Hitachi 32LD7200
    Toshiba 32WL56
    Samsung LE32R41B
    Hitachi.. well out of stock everywhere. The Toshiba looks decent and seems to get favourable mentions in here (shame I can't find a review on homecinemachoice.com), and the Samsung favours highly too (can't find a manual on Samsung's site.. can't even find the model at all! Would appreciate a link if some has it.), and looks (appearance-wise) the best of the lot.
    I have a Topfield Freeview recorder (RGB connected at the moment) and a Panasonic DVD-S75 (RGB also, but has component), probably looking at HDMI DVD player in future, and definitely intend hooking up a PC via DVI (D-SUB if non-DVI)
    As I'm disregarding the Hitachi, would there be any real difference between the Tosh and Samsung models for my intended use?
  2. manzee
    manzee
    May 25, 2005
    25
    The Tosh has no dedicated component input, you have to go through VGA. The Samsung might have tearing problems.
    Decide which is the lesser of two evils I guess!
  3. groovyf
    groovyf
    Jan 10, 2005
    78
    Hmm. According to the Tosh manual, only one of the 2 SCARTS is RGB :/
  4. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    Manzee; the Samsung tearing is no longer an issue; Samsung has a fix for it now, so that shouldn't affect groovyf's decision in any way.
    The Samsung is a fantastic screen, and looks exceptional when fed a good signal. Poorer signals look ok, but that's the case with most LCDs.
    You cannot get 1:1 mapping through the HDMI port on the Samsung, but the VGA looks amazing. You virtually cannot tell the difference between VGA and DVI/HDMI quality on it the VGA is so good. This also frees up your HDMI/DVI port for an upscaling player, rather than having to swap cables around all the time.
    I don't think you can go wrong with any of these screens, but I know from experience how good the Samsung looks with a good signal. (good quality freeview/ntl channel, DVDs, HD clips)
    Here's a shot I took of the "Madagascar" HD DivX clip on it:
    [​IMG]
    This shot is straight out of my camera; the only thing done to it was shrinking the size to go online.
  5. -=Sniper=-
    -=Sniper=-
    Oct 26, 2003
    32
    andrewfee, is the samsung any good as a monitor?
  6. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    Fantastic as a monitor. The VGA input is better than I've seen on any "proper" LCD monitor.
    Very crisp when it's got 1360x768 sent to it.
  7. -=Sniper=-
    -=Sniper=-
    Oct 26, 2003
    32
    ah, what graphics card you using? how about the gaming on it!
    currently considering the Dell 2405 but also want good HDTV support.
    thanks
  8. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    I've had mine hooked up to my Powerbook (ATi 9700) and two PCs; nVidia Geforce 4MX and ATi Radeon 8500.
    I've tried out the Doom 3 and HL2 demos, and they looked unbelievable.
    This will do a far better job as a "TV" than the Dell, and is just as sharp as a monitor. It's lower resolution though, so it may not be enough, depending on what you do. (if you just browse, email, chat etc it's fine)
  9. groovyf
    groovyf
    Jan 10, 2005
    78
    Ta for the input andrewfee. Much appreciated.
