Question Choice of 2 rooms, which one is best
Lord Essex
Hi All,
I’m moving home soon and will have the choice of 2 rooms to use for a home cinema. I’m hoping to fit a 7.4.2 speaker set up and would like to fit a screen of at least 100”.
Which room should I choose?
1, 15ft 3in x 8ft 8in
2, 12ft x 11ft 6in
thanks for the advice
Koipin
It all depends on window and door location. Id go for the square room as it will give you a better sound stage across your LCR.
A 100" screen is going to be approx 7' 6" wide. Your front speakers won't have much space to express themselves.
Roohster
Do you have any room plans?
Also, are you going to be using free standing speakers or are speakers mounted behind an acoustically transparent screen an option?
If the latter, the long narrow room could be the best option.
Lord Essex
Here’s the plans, I’m leaning towards the longer room myself and am open to an acoustically transparent screen.
pugheaven
I personally would use the longer room for 100", simply because upstairs in my living room I'm running 100" screen and my head is 13ft awat from the screen... and it's perfection... I could move closer... but for me, length would be better there mate, just opinion though
Tom @ Cinehome
AVForums Sponsor
Bedroom 2 is the better option with more flexibility also for the placement of speakers. An AT screen is the way to go too for that authentic cinema feel.
Lord Essex
It looks like I’m going with bedroom 2. Let the fun begin
thanks to all for the advice
Tom @ Cinehome
AVForums Sponsor
Perhaps this kind of arrangement?
Yes exactly, although all the speaker angles would need carefully checking from the MLP. I would recommend placing both subwoofers on the front wall if possible? Your arrangement is a great starting point.
Tom @ Cinehome
AVForums Sponsor
We'd be delighted to assist further. Please don't hesitate to get in touch for any equipment / layout advice.
Triggaaar
Kudos for adding a drawing to the discussion.
I'd move the Atmos speakers to a half way line between the centre and the front left/right.
And I'd probably put the rears just inside the window opening, if there's space for a blind behind.
And I'd put the side surrounds at 100 degrees (so just behind the MLP)
Lord Essex
It’s just for me,
