Choice between......
Discussion in 'General TV Discussions Forum' started by Steve22, Feb 17, 2005.
  1. Steve22
    Steve22
    Im looking at two TV's at the minute
    Panasonic TX28DTX1C
    Panasonic TX28DTX10C
    The only major differences (apart from the colour) are the 10C has 100Hz scanning and the 1C has 50Hz. Also the 10C has a more powerful speaker output.
    Other differences are negligible - unless you know otherwise?!
    Is it worth paying the extra £80 for these features? Does 50Hz / 100Hz make much difference?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Steve,
    Depends on how much you, and anyone else likely to watch, are troubled by flicker.
    Some people are, some are not.
    Suggest you do a test at your local dealer.
    Be aware that flicker is more noticeable out of the corner of your eye, as you'll see when looking at a line of sets in the shop.
    Obviously you'll be looking straight at whatever screen you eventually get at home, so don't be caught out.
    As a TG, I agree there's no point in spending more than you have to!
  3. MKD
    MKD
    so is 100Hz TV better then 50Hz TV?Especially if the TV signal is analog 50Hz.
  4. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    there really isnt a definite answer to this question. If you do a search you will find loads of threads on this. Some people wouldn't buy a 50Hz set whilst others wouldn't buy a 100Hz set.
    my advice look at them both if you dont see a diff buy the cheaper set and put the extra money onto a decent scart cable and some dvds to watch!
  5. Steve22
    Steve22
    Cheers for the advice guys - I'll have a test of them both.
  6. Chris Hedlund
    Chris Hedlund
    Try and find a 50 and 100Hz set side by side. There's much more to it than flicker. In particular the 100Hz will have better definition, crisper images and a more 3D depth to the picture.
    Balance this agains the 100Hz artifacts which are worse with some makers than others.
    I agonised long and hard too, but eventually bought 100Hz and have not been disappointed.
