chipset on pwd6
Discussion in 'Plasma TVs Forum' started by johnski, Nov 18, 2004.
  1. johnski
    johnski
    Just bought a pana 42pwd6 from av-sales :thumbsup: and in order to ensure that i get the best picture quality i was wondering about a few points.
    1. what chipset does the pwd6 use for de-interlacing/scaling
    2. what is reckoned to be the best chipset for de-interlacing/scaling
    I have a pio 470 connected through component video and to be honest i can't see much difference between outputting a progressive signal and interlace signal so i'm guessing that the chipset in each is roughly the same.
    John
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You are probably right. The panasonic plasmas deinterlacing is not bad at all, so you need a good player to better it. They do not advertise what they use, their own prsumably, but it works, and at least as well as a good budget DVD player. Give it prog scan from an arcam, decent player from H-K, denon or Onkyo, you will see the difference much more clearly.
  3. rafaqat
    rafaqat
    Sep 28, 2004
    82
    So getting a budget (sub £100) prog scan DVD player will probably give me a similair picture to the one I'd get if I played a DVD through my normal DVD player and let the plasma de-interlace?
  4. johnski
    johnski
    Maw,
    This is what i'm thinking, but where is the crossover between the dvd player producing a better progscan picture and the pwd6 producing a better progscan picture.
    Do you think that it would produce a better picture on the pwd6 using something like a denon 3910 @ £800 or a pio 470 @ £85 fed to something like the cinemateq picture optimiser @ £500
    All this is giving me a lot of food for thought !!!!
    Rafaqat,
    I guess it all depends on the chipset and how its implemented , this is whats causing my brain to hurt, where's the crossover when its best that the pwd6 does it and when the dvd player best does it.
    John
