Chipping Xbox
Discussion in 'Xbox Forums' started by spikeyboyo, Jul 15, 2002.
  1. spikeyboyo
    spikeyboyo
    Anyone know where i can get my xbox chipped. Dont really want to send it off in the post, dont trust the mail.
    Live in Kent.
    Spike
  2. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
  3. spikeyboy3
    spikeyboy3
    thanks for the help.
    Spike
  4. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    did you get your xbox chipped??
    if not i know someone in bromley that might do it for you
    let me know
    jason
  5. spikeyboyo
    spikeyboyo
    cheers - ive found someone in Tonbridge that will do it for £65 supllied and fitted - going ot get it done once i get paid :)
    Can you recommend which chip is best - recommending the exoX chip to work in conjunction with evolutionX.
    Spike
  6. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    I have the Enigmah chip which works a treat with EvoX, Video Select CD, and any game I throw at it.
  7. Big Jim
    Big Jim
    Bit OT, but can anyone reccomend a reliable fitter for a PS2 messiah chip, preferably in London?
  8. NeoBlade
    NeoBlade
    Big Jim, if you can hold on for another 2-3 weeks mate you should be able to buy a Messiah "clip". These clips will basically cover all the 23 connections on the chip itself turning it into a stupidly easy 2 wire (non-solder) connection. Check out their official site at http://www.china-messiah.com.
    I installed a Messiah chip myself back in Feb and it was rather easy (compared to the evil NEO4.1... 44 wires... Evil >_<) and it works superbly. Full speed FFX gaming... Its all good.
  9. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    NeoBlade,
    Dont suppose you have found any VCD/DivX players for the PS2 have you?
    I gather they only work on PS2s (If they exist at all! They look pretty real, but don't seem to do anything....)
    Cheers!
    Paul.
  10. NeoBlade
    NeoBlade
    As far as I know there isn't any VCD players for the PS2, nor are there any DivX ones because that requires a percentage of work from the CPU. To be honest with you I haven't done any extensive research into it, but I haven't found anything so far.
    If something is out I'm sure that someone would post it up. I'll have a look for you in the morning mate, since I need to get up early and build a PC. Laters.
