Chipping R2 players
Discussion in 'Blu-ray & DVD Players & Recorders' started by RMCF, Apr 22, 2001.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,509
    +774
    Couple of questions:
    1) Does anyone know of any suppliers of chipping kits for R2 players (preferably manual region selection). And at what price?
    2) How hard are they to fit?
    Thanks.
  2. fishyben
    fishyben
    you can get DIY kits from this bunch www.techtronics.com
    They rate them on how difficult they are to fit, some are easy and some require the use of Nanobots they are that fiddly ;)
    [ 22-04-2001: Message edited by: fishyben ]
  3. RMCF
    RMCF
    Aug 24, 2000
    7,509
    +774
    Cheers Fishy
