Chipping on laminate floor?
Discussion in 'General Chat' started by johntea, Mar 15, 2006.
  1. johntea
    johntea
    Feb 4, 2005
    252
    One of the bedrooms has quite a few 'chips' in a certain area of the laminate flooring. They're in the same sort of area but spread out quite a bit. As far as I am aware nobody has hit it with a chisel :rotfl: and just been subject to daily usage (Walking on it!).
    Why are these chips appearing :confused:
  2. Bobdk
    Bobdk
    Feb 2, 2006
    396
    28
    Edinburgh
    +55
    Hi Tea,
    You haven't got wimmin' walking over it in their stilleto's have you?
    Also, are the chips on the edges of the strips or in the middle?
  3. johntea
    johntea
    Feb 4, 2005
    252
    No and in the middle
  4. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Too much hammer on the bed..........;)
  5. GBDG1
    GBDG1
    Feb 5, 2006
    7,447
    +1,260
    I would expect it is from when you get those annoying tiny stones stuck in your shoes.
  6. Jake
    Jake
    It helps if you remove the spikes from your subwoofer:nono:
  7. Bobdk
    Bobdk
    Feb 2, 2006
    396
    28
    Edinburgh
    +55
    Mr T,
    Have you laid the underlay? Did you clean the floor properly before laying the laminate? It could be that there is grit/dirt/sticky-up bits underneath the areas you mention that is causing some pressure through the laminated sheet, end result being it "pops" the top laminated layer off. If the floor is uneven it might be causing the laminate to flex? Failing that it might be a defect in the laminate. Further investigation looks necessary. best of luck.
