Chip installed on my XBOX - is it working ?
Discussion in 'Xbox Forums' started by dUnKle, Aug 11, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,625
    +2,494
    Purchased a Xecuter Lite 2.3b and Xapter from Baldbouncer
    Arrived today and installed it - now however im not sure if it works - the xbox works and loads with original hard drive and I can play games - but thats it
    Do I need to put a new bios on the chip and if so how ?
    I also purchased a pre modded hard drive from premodded but when I install this I just get a red flashing power light
  2. smokingreen
    smokingreen
    Apr 23, 2004
    681
    Derby
    +17
    Do you see a blue light on the chip itself ie in the xbox when the power is turned on? This indicates that the chip is at least getting power.
    If you're seeing a blue light then you have to put the chip to the on position on the switch. When you do this you should either see the cromwell bios screen or you may have a black screen but in both cases the dvd tray should pop open allowing you to put a cd-rw with your bios burnt on it.
    Chances are that if none of the above is happening then your chip is misaligned, so you need to realign and try again.
    I recomend you head over to XS (www.xbox-scene.com)and read some tutorials becasue its all fairly overwhelming when you first try it all - gets easier though!
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,625
    +2,494
    Now got the insert disc message
    Just need a bios
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Do you have a bios and/or are you aware of the procedure for flashing your chip?
    K.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,625
    +2,494
    Thanks all
    Got it workin
    But how do I get my MS dashboard back
    I dont seem to be able to turn the chip off
    Have succesfully installed and run my Xecuter Lite 2.3b with Xapter chip
    Its Enabled - On Bank 1 and Bios is Protected
    However when I switch the chip OFF and reboot (for live etc) I get a message about the box being faulty and a number 5 in top left corner
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    Error code 5 means that the HD isn't "locked".
    The original Xbox HD contains a lock code that corresponds to your motherboard. During the boot process, a check is made to verify the fact that the original HD is in place, and if the correct response isn't received (as in your case) you get Error 5. There are facilities around that will let you lock your new HD, the easiest of which is present on Slayers...
    K.
  7. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    FYI by the way, more details on the various Xbox error codes can be found here :)
    K.
