Chip Fitted ! What next?
Discussion in 'General Video Gaming Chat' started by installer09, Dec 31, 2003.
  1. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Hi guys , ive just fitted a Xecuter 2.3 lite chip to my xbox, it took me about an hour . I thought i just had to plug it in and away i went , its been flashed with Cromwell v2.27 , but im not sure what to do next , can anyone help please?
  2. Sly
    Sly
    Apr 28, 2002
    1,500
    west mids,England.
    +51
    a trip to your local car boot?
    :nono:
    lol
  3. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    what the heck is that supposed to mean? lol
    anyway, there's loads you need to do, installer09. To be honest, you should have researched all of this BEFORE you bought the chip:rolleyes:
    the first thing you need to do is create a bios cd to flash the chip as you can't do sod all with cromwell.
    head over to http://forums.xbox-scene.com for more info.
    a question: look at the dvd-rom tray. does it have three holes (1 big one in the middle and 2 small ones at the front) or just 1 big one?
    if its only 1 big hole, then you'd better hope youv'e got a dvd writer.
  4. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    or use A cd-rw. Samsung drives mean sod all, they have a betteer chance of reading CD-R (key word is chance). What you will need is a bios for the chip and a replacement dashboard. I recommend using slayers auto installer (search on google for it), this will autoinstall bios dash and a few apps.
    Rich
  5. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Thanx guys , but I cant find Slayers anywhere! keep looking in newsgroups but not sure how they work.
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    samsung drives mean a lot when you try and make a bios disk.
  7. artemis60
    artemis60
    Aug 1, 2003
    30
    east Sussex
    Have a look here
    http://www.copying-xbox-games.com/
    some very usefull basic help and if you look at the Evolutionx tutorial it will tell you where to find the files
    HTH
    Nick
  8. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    I spent hours there yesterday with no luck !
  9. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
  10. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    will the northern monkey installers disk from premodded do it?
  11. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    ive no idea ive never used it. But, ive only heard good things about SlaYerS, so do yourself a a favour and get that.
  12. Jason S
    Jason S
    installer09,
    I can make the Version 2.5 slayer kit available to you, on a private ftp site.
    It's 30Mb in total though, I'll pm further details to you
    you may also find this site useful for future reference
    http://www.newzbin.com/browse/cat/p/consoles/xbox/
    Not knowing what version xbox you have I can't say if I have an appropriate BIOS for your chip, but I do have Executer 2 4977 in various flavours if appropriate.
  13. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    i though slayers 2.5 was 108mb?
  14. Jason S
    Jason S
    That's the full self extracting archive .exe with all sorts of stuff crammed in there, but the .iso is the imortant piece.
    the .iso file itself is 48,824,297 bytes, and when it's compressed using winrar it comes just under 30Mb.
  15. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Thanx Jason thats great ! its downloading now , can I burn the disk with windows or should i use nero?
  16. Jason S
    Jason S
    I tend to use nero, never tried burning an iso with windows.
    for nero version 6 the option you want is Burn Image, under the Recorder option, I can't remember where it is in earlier versions,
    And you'll probably be best off using a cdrw, as "most" xbox drives can read these as opposed to standard cdr's.
