Chimney Bracket Strap For Aerial
Garrett
Does any one know where to purchase something like this in the UK.
Just been up to check some wire to my radio aerial and found the bracket was loose and looks like the wire that was round the chimney breast stretched so tightend the bolts up that pull it and it just about tightened it up.
Without having to take the whole lot down thought I could get something like this made for the purpose (not the stuff used for trucks for locking loads down). The firm where I was looking went out of business in 2017 so no luck where I found picture below.
Like this, (warning site coming up not secure so may not want to look) Chimney aerial strap bracket
Garrett
There's one here:
Their newer design is available direct: 8 Stack Strap Bracket
I not realized the ratchet was part of the bracket and was thinking it being more like a belt with a ratchet system on it that you could crack to get some tension on it. Anyway may get one and supplement the one I already have if the fixings for the mast to line up.
Upvote 0
