Checking Linn serial numbers
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by consciouspnm, Feb 1, 2005.
  1. consciouspnm
    consciouspnm
    Jul 24, 2003
    Huddersfield
    Is there any way to check the given serial numbers of goods on ebay to confirm they are genuine?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    If you're concerned you can try and get the serial number off the seller and then contact Linns helpline. They will be able to give you the date of manufacture.
    HTH
