Checking how many hours my panny has been on?
Discussion in 'Plasma TVs Forum' started by snakeeater, May 24, 2004.
  1. snakeeater
    snakeeater
    Jul 26, 2003
    Sorry for being a noob here guys but its been a lot to learn in such a small space of time. How do I access the hidden menu to see see the time that my panny has been on for?
    I saw the link to the hidden menu's and tried the key presses but couldnt access it.
    So.......what is the exact key sequence on the remote to access the timer?
    Many thanks in adavnce :thumbsup:
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Depends on which panasonic.
  3. snakeeater
    snakeeater
    Jul 26, 2003
    Its a Panasonic TH-42PW6
  4. jmack
    jmack
    Originally posted by jmack
    here goes
    hold the volume button on the panel in while pressing the button under the power button (the status button) 3 times very fast
    then a menu box comes up high light the iic mode then press the sellect button (the square button on the remote) in the the top right hand corner it will say what signal is being displayed only on component i have tried this
    to return press the the R button the high light id mode then power off on the remote or panell
    another thing if you high light the sd mode then sellect it tells you how many times you have powerd on and off the panell and even better an hour meter i thing the hours are on the right PT and the on/off meter WT is on the left ,
    i dont know what the rest of the stuff is
    PLEASE BE CARFULL IN THERE
  5. snakeeater
    snakeeater
    Jul 26, 2003
    Thank you very much for that, I will give it a go when I get home :)
  6. Ancillotti
    Ancillotti
    Does anyone know how to do this on a PE30? There seems to be no status button on the panel itself ...
  7. Omar
    Omar
    This does not seem to work with my Panny W6 - Altough I can access another hidden menu by highlight OSD and then holding down the surround button - dont know what the menu gives me and also did not change anything !!
