Checking hours on pio 436xde
Discussion in 'Plasma TVs Forum' started by stevedster, Oct 27, 2005.
  1. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    Hi, does anyone know how to get to that service menu option where i can check how many viewing hours i have clocked up on my 436 ?
  2. vicente
    vicente
    May 10, 2005
    27
    You can see this in the post "435HDE Hour check...?" from Jun 16th.
    It seems it applies too to the 436
    Regards
  3. HarryW
    HarryW
    Make sure the plasma and the media box is in standby.
    Press information (below 9) on the remote (just press, do not hold)
    Wait 4 seconds
    Press LEFT, UP, LEFT, RIGHT and POWER (on the remote)
    Had to try a few time before it would work
  4. bix
    bix
    May 24, 2005
    356
    Manchester
    +7
    Thanks harry, works a charm! Now I can monitor how much time I spend glued to the sodding thing!
