Checking DVD Authoring Software
Discussion in 'Blu-ray & DVD Players & Recorders' started by DVDandVCD, Jan 16, 2005.
  1. DVDandVCD
    DVDandVCD
    Hey,
    Is it possible to check what software was used for authoring andrecording certain DVD? I have some DVD which is compatabile with every device I tried. I would like to find out with which program was it made. Also what is the most compatabile DVD-R disc? Princo turned out to be BAD although it got decent feedback. Is there any other software than neoDVD that can record in good quality straight to VOB files? PLEASE HELP ASAP!!! Thank is advance.
  2. DVDandVCD
    DVDandVCD
    help!!!
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    I think that DVDInfoPro (freeware, from here) can display the authoring stamp (aka 'Implementation Id') of +R or -R discs.
    I don't think you are using 'compatibility' in the right context, but if you don't use good quality discs you have no chance of comparing compatibility. For information on various manufacturer's disc products, see here.
    You're going to have to explain "straight to VOB files". Otherwise, any DVD burning software such as Nero will copy a ripped bare MPEG2 file to DVD, which will play in some multiformat players.
