Checking AV32R spec?
Discussion in 'AV Receivers & Amplifiers' started by mandril, Sep 9, 2003.
  1. mandril
    mandril
    Jan 12, 2003
    174
    19
    Sorry about the naff title I couldn't think of any short way to put it.
    I'm picking up a second hand TAG Mclaren AV32R this week and I dont know how to check whether the item has the specification listed by the seller when I collect it. the 7.1 and 5.1 bypass are easy enough by looking at the rear, but what about the software version, dacs, PLII, DTS-ES etc?
    Any help would be appreciated.
    Many thanks
    Ricky
  2. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    The software revision is visible when you power up the AV32R...it appears on the screen.
    As for the internals,if the DACs have been upgraded,it should be marked on the front,and the other options(PLII/DTS-ES)will be found in the menu options.
    DTS-ES and DTS-ES Neo6 both require the 7.1 upgrade.
    If you have the serial number,the Tag Helpdesk may be able to verify some of those things for you,if you explain the situation.
    I take it the seller has listed the spec for you?
  3. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    As regards the Dac's i would contact Tag. When i had my first Tag and i had the DAC's installed they did NOT change anything on the front panel at all other than a transparent stick-it note on the display panel to say that it had been up=graded with 24/192 DAC's, in the options fitted menu it definately did say that the EX board was installed but i really do not recall anything regarding the Dac's - take the appropriate steps via the serial number and Tag or the registration of up-grades to make sure.
    Regards
    Steven
  4. mandril
    mandril
    Jan 12, 2003
    174
    19
    Thanks.
    I have the serial no, I'll give TAG a call. I hadn't given that a thought.
    Ricky
  5. mandril
    mandril
    Jan 12, 2003
    174
    19
    I emailed the help desk at TAG and this was there reply about how to find out the spec.
    "Regarding what it has fitted, simply go into the On Screen Display > Change Set-up > AV Options + Backup. This page will show you what has been fitted to this unit".
    Would anyone with the AV32R please have a look on theirs to see if this works
    Thanks again
    Ricky
  6. edward
    edward
    Apr 2, 2003
    855
    32
    Reading
    +26
    This does does work - I've just tried it on the Dual Sharc model I'm trying to sell. I think it works on the older models too. However, you need to bear in mind that the old model runs a limited (but still excellent) set of features. The newer model runs the same software as the AV192.
  7. mandril
    mandril
    Jan 12, 2003
    174
    19
    Edward
    Whats the difference between the old/new models?
    When did they change?
    cheers Ricky
  8. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    edward, where is your DS advertised?
  9. steve36
    steve36
    Dec 11, 2002
    924
    Warwickshire
    +28
    Edward,
    Why are you selling, and again, where ?
    Steve.
  10. UrbanT
    UrbanT
    Jan 6, 2002
    12,843
    Aldershot, Hants
    +3,032
    Edward has stated he has bought a 192R, hence the sale of the DP.
    Its for sale on Tags website in the 2nd hand market :)
