Check this out - need advice
D
Derek Mitchell
in your esteemed opinions what is better....
1) Combined Home Theatre kit i.e Sony DAVS 550
OR
2) Seperate DVD and amp/spkr kit.
I have just got the DAVS550 however, not that impressed. Also, the davs 550 does not have a scart output, lathough has s-video.
What is better.
Thanks in advance for your thoughts.
Derek
Kirk
Decent seperates are pretty much a guarantee to give better results.....but match the items well.... decide on your total budget and them search arround for the good equipment that will fall within that figure.
S-Video is good, but in general RGB Scart is better. You need to ensure that your TV can accept the RGB signal, otherwise you will just use a composite signal over scart which will be inferior to the S-Video output.
bobble
Originally posted by Derek Mitchell
OR
What is better.
Derek
Derek, seperated are no doubt the best but it really depends on your budget and if you have a fussy wife! For the money the Sony is a great buy (got the S550 myself). Due to subtitle problems with the Sony model at the start I have had 3 DAV units. All 3 units seemed to lack bass at the start, either I get used to them after a while or after a weeks use the bass quality improves.
