Cheapish wall mounting brackets?
Discussion in 'Home Cinema Buying & Building' started by torrent, Jan 3, 2003.
  1. torrent
    torrent
    I can't believe the price of these things. How can they justify £300 - 500 for what is essentially a simple bracket. I appreciate that it has to hold 30Kgs of screen but even so.
    So, does anyone have a good resource as to where I can purchase a universal (as in generic, not the manufacturer) wall mounting bracket at a reasonable price?
  2. jmack
    jmack
    nexnix do the unicol bracket its about 130 i think i paid
  3. torrent
    torrent
    Thanks, that looks like what I am after. Are these safe to fit to plasterboard walls?
  4. jmack
    jmack
    not straight on to plaster board no.
    find the studs hopefully they will be in the same place as the holes on the bracket.
    there a few threads on this if you look
  5. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Just because it is plasterboard doesn't mean it is a stud wall!
    Most new houses have a breezeblock construction for the load bearing walls, and then the plasterboard is glued to the breezeblock using plaster as glue around the edges of the board. It you have a solid sound when you knock the wall every 12-16 inches, you have probably got studs. If the gap is any larger then no studs, just a 20mm gap between the board and the breezeblocks.
    Kind Regards,
    James
  6. torrent
    torrent
    OMG what a blimmin' nightmare.
    Thanks for the info. I never realised I would have to take a degree in Audio and Video Electronics as well as become a construction engineer just to install my Plasma. :)
